AEROCOOK
Master Chief Petty Officer
- Jul 28, 2004
- 872
My 76 Johnson 20hp aquired a poor idle this summer, and I am looking for tips on things to check. To begin with, let me fill you in with some possibly relevant info...
Half way through the summer the pick up coil was replaced because the motor suddenly died and I diagnosed no spark. After I replaced the coil the idle problem surfaced and I found that the only way I could get the motor to idle at all was with the slow speed needle 3 and a half turns out. Even at this setting (which I think is extreme??) the idle is inconsistant. I have cleaned the carb twice with no improvement. I noticed quite a bit of play in the throttle linkage allowing at least half an inch of back and forth movement in the plate, is this normal? Are reeds a common failure on these motors?
