I am attempting to repair the reverse lock on my sons 85HP 1987 Force Outboard before I return home on Monday. I have to replace a broken Nylon REVERSE LOCK ARM... and I have all of the parts to do the job..PROBLEM.. now that I have removed the spring pin that held the broken nylon reverse lock arm on the shaft, HOW DO I REMOVE THE SHAFT FROM THE TILT ASSY. How is it held in place? Any help on this problem would be greatly appreciated so I can fix this problem before I head back across the U.S....
