mr snowman
- Jan 6, 2007
- 7
Hi guys, I am new at this whole boat thing so bare with me. I bought a 1989 Forester 160 Sport that has a 3.0L OMC (4 cylinder) in it. I was told it is a chevy block. The first year I had it there were no issues. The second season I noticed a small water leak around the vacuum tube connection to the manifold (I think that is what it is) that goes from the carb to the manifold. The connection is right near where the gasket is. It still ran ok, but once in a while the motor would bog down and back fire upon initial WOT. I would back the throttle off and give it WOT and there would be no issues. In addition, while cruising around the lake at slow speeds the motor would rev up and down slightly. The dealer said he could look at it but suggested he could take care of it when I pulled it out of the water. Other than that, there were no issues. So the dealer looked at it and "found nothing wrong"
Last season was a little different, The initial launch/ride I noticed the leak again and it was running real rough. So I brought it back to the dealer and they replaced the exhaust manifild gasket. After launching the boat again, the leak was still there and I checked the oil, sure enough there was water in the oil. Mind you I always check the oil and there has never been any water in the oil. I bought it back again and they took the head off and sent it out to check of cracks, also the compresion was good. No cracks were found, but they did find some slight warping so the heads were machined, They put on all new gaskets along with the machined head and guess what? The vacuum line area still leaked , but there was no water in the oil. The motor still has the issue of reving up and down slightly and still boggs/backfires once in a while when I give it WOT.
Can it be as simple as the vacuum leak that is creating the motor performance issues? Can I put some JB Weld on there and call it good? Maybe buy a new manifold?
Or could the carb be dirty/worn and needs to be replaced and there is no link to this vacuum leak?
I look some numbers off the motor if it will help: IM07121RQ N2356
I also took some pictures of the "leak area" if it will help I can email them out.
Thanks for your help
