Kent Olsen
- Aug 9, 2006
- 6
A couple of years ago I let my mechanic talk me into removing the failed VRO and premixing. I decided to put a VRO back on the motor and bought all of the requisite parts. The pump installed just fine, but the conversion from 3 to 4 wire is proving to be a challenge.
The instructions state that the 4th wire in the connector should be connected to the purple wire in the wiring harness. Well, there is no purple wire, but there are a pair of wires that are purple and pink.
How do I determine which of the existing wires should be connected to the new purple wire?
Also, when the VRO was removed, a brown wire was cut and terminated. The brown wire fans out to be 4 brown wires right after the plug. Does this wire need to be reconnected?
Thanks,
Kent
Thanks,
Kent
