Re: 89 OMC cobra 4.3 leaks water through transom???
I maybe Wrong,.... But,....
A 1989 boat with a Leaking Transom would most probably be leaking Either,....
Thru a leak in the Bellows,.....
Or,....
The Transom is Rotten,+ due to the Compression of the Non-existent Wood,......
It's started Leaking around the Transom Shield Gasket...........
IF its the Bellows,..... It's repaired from Outside the hull.........
If it's actually Leaking around the Transom Shield,......
The Drive,+ Motor, along with the Transom Assembley, both Inner,+ Outer,..
Have to be Pulled to access the Problem.......
'Course,..... I Don't Do OMCs,..... But I still believe this to be True..........
