Synchronizing linkages
teslaman
I recently installed a rebuilt powerhead on my 1973 115Hp Johnson. To do the installation, I had to remove all of the ignition, fuel, and electrical components. I have just about everything back together at this point and have been reading in my Clymer & SELOC manuals about how to sync the linkages.
Is this a difficult process? Before I ever start the engine, how can I tell if they are set appropriately? When the remote lever is pushed forward, the lower unit should go into gear and the throttle should increase. I can see how this process works by messing around with it, but how do I know when the settings are right so that I do not damage the lower unit or keep the motor from reaching full throttle?
ezeke
Re: Synchronizing linkages
Best bet is go to Ebay right now and enter 320027482358 in the search window. It does not matter if you use Evinrude or Johnson manuals, because they are the same engine.
The OMC service manual has model-specific information.
OBJ
Ezeke is right....the whole procedure for sync and link is just to long to post.
I know it sounds like a broken record but, getting the OEM service manual is THE one best thing anyone can do for their engine.
tschamp20
hey tesla ive got the same motor as you and own the factory manual.if you want i can give you the proceedure or you should def. get that manual above.by the way its not that long at least ours isnt!two maybe three paragraphs.itll be tomorrow evening at the earliest though. let me know or catch that manual while you can there a rare find.
tschamp20
so i kinda lied its more than 3 paragraphs. here it is.
tschamp20
a little out of order,sorry hope this helps.if theres anything else let me know
teslaman
Thanks tschamp,
It looks like these directions are much easier to follow than the ones in the SELOC or CLYMER manuals.
I'll also look into getting a factory manual.
tschamp20
no problem. im gonna being the same thing in about a week hopefully.youve been asking the ?'s i was gonna ask.thanks for saving me the typing!peace out
teslaman
It'll probably be a few weeks before I can get to mine. I've got the powerhead installed along with the rebuilt carbs, but I'm fixing some other issues along the way while I have the thing apart.
Stay in touch, I'd like to know how everything goes.
