Re: 1981 Evinrude 35hp compression
Anything above 90psi on both cylinders and within 10 > 15% of each other is considered very good merc. I have had engines run very well on compression in the low 80's and even a little lower on occasion. But the real key is how close they are to each other.
True, when the compression starts getting down below 80, either time for a for a rebuild or new engine.....this in consideration if a good decarbing didn't help and there are no leaks in the head gasket.
