Texasmark
- Dec 20, 2005
- 14,899
We are always yakin about proper engine height and trim and all that setup stuff to maximize performance.
The last couple of days we have also been yakin about the "Fat 50", first American V4 engine produced by OMC back in the '50's.
Also still hammering the question (to me) of torq and it's application in propelling a boat.
So I'm quoting engine specs of the past (addressing torque) and obviously I am in the www.old-omc.de site getting my info so that it's accurate.
So I was in the spec chart on page ..../index2.html and scrolled down below the spec chart where the pictures are.
If you are into setup, you must go over there and check out the picture of the fat 50 with 5" extension (to make it 20"), hanging on the transom of a beautiful Mahogany boat, and look at where the antivent plate is located with respect to the bottom of the boat. Also notice the water pickup (one of 2)......the little plate with 2 screws in it just above the anti vent plate......the other one is on the front side of the exhaust deflector, where i'm told it was deliberately placed so that propwash could keep it swept clean of debris........but propwash, when you're stuck on the sandy beach, also cuts your impeller to pieces. I'm told that the one on the side is for removal if running in a tank of water or when backing up, as that manuever starves the one on the exhaust deflector.
So, I guess one of the reasons for the low mounting was to insure that the water pickup could pickup water.....but geez what kind of performance could they have gotten out of those old OMC's had they had water pickups like Merc on the gearbox housing.
Maybe that's one reason Merc had the speed on them, they were sitting higher on the transom and as a result were able to run faster with less drag......and the lower unit was sleeker, and the engines revved to 6000 rpm's.
So much for today's trivia.
Mark
Mark
