Throttle trim wiring help needed!!
MN86_4winns
I dismantled my throttle handle on my '86 4winns and did not write down the wiring connectors. The have 4 wire connections to make for my trim. The 4 wires in that come from the trim are purple w/white, blue w/white, green, & red. The wires in the handle are light green w/white stripe, Purple w/white stripe, Light gray w/white stripe, & Red w/black stripe. Thanks, next time I promise to write them down.
Haut Medoc
Re: Throttle trim wiring help needed!!
The make of your boat's hull is irrelevant.....
You need to post what type of drive package you have.....;)
flabum
Are you sure that "light gray" wire isn't light blue? if so, just connect wire colors together.
In most trim systems, green is down, blue is up, red is power and purple is bypass.
Coors
have a '88, will get back with in am
