Re: tilt trim will lift motor but will not lower it
Had the same problem with my 90. Did the same thing you did-- Didn't fix problem. Gave up. Found that if I pushed real hard on motor to lower it some, it would then lower using the trim motor. Also found that not tilting all the way up reduced but did not eliminate problem. Found that by constantly working up then down, provided there was room for more up travel, it would finally tilt down. Went so far as to completely replace pump head and didn't solve problem, so it is probably a sticking tilt cylinder or a stuck open bypass valve in the tilt cylinder. A small bit of crud in the ball check will do this. Thats all I have!
