AguaSki
- Jul 4, 2005
- 545
I just returned from picking up my boat at the local J/E dealer after having my spring maintenance completed. The first thing I noticed was that my 1 year old Rapture prop was missing. The prop was in new condition and had no dings or scratches. After questioning the owner and the mechanic that worked on the boat, it was determined that a thief must have reached through the fence to where my boat was parked to steal the prop. The owner is a stand-up guy and offered to replace the prop at no cost to me. After he made a few calls, he could not find another Rapture. He told me that he would make some more calls, and also said he would reimburse me if I was able to find a prop on the internet. He was also open to replacing the prop with something other than a Rapture. So now the research begins.
I dont see a Rapture here on Iboats, but I do see Apollo and Stiletto. I seem to recall from a previous thread that Michigan Wheel was replacing the Rapture with the Apollo line-up. Is that correct, and is an Apollo prop an equivalent replacement? To be truthful, I was not happy with the performance of the Rapture, but because the shop owner has been good to me in this instance, and previous instances, I dont want to take advantage of him in this situation. I only want a prop of equivalent technology as the Rapture. I figure it is shops responsibility to replace what was stolen on their property, and it is my responsibility if I want a prop that is above and beyond what I already had. Any thoughts on where to find a Rapture or something of equivalent technology?
These are the details on what I had:
15 pitch Rapture
140 hp Johnson, 1978
Glastron SSV-188, 1978
WOT RPM 5,280 (I have had 3 tachs in the last year and all had the same reading. The current tack is a digital OMC.)
37 mph verified by GPS
Smart Tabs
The motor has been raised two holes, I have one hole left to go if needed
Good hole shot for skiing and tubing
The boat is mostly used for water sports
My RPMs are too low, so this may be an opportunity to correct things a bit.
Please share thoughts on what might be a suitable replacement prop that will be fair to me and the shop owner.
15 pitch Rapture
Smart Tabs
