I recently got some great advice here and had one other question - my previous motor was a 65hp Johnson (1974 I think). Prior to the boating season, it was fully tuned up with new impeller, lower oil, carb kits, plugs, etc... The compression was a solid 110-115 on all three cylinders and ran perfect the entire summer until coming home one night I felt a THUD! and a sudden drop in power. I was a good quarter mile from the ramp, so I pressed on and actually made it back.
Upon inspection, there was a hole in the crankcase large enough to see the crank and connecting rod. I tore the entire powerhead down and realized part of the piston skirt had broken off. The piston was still connected to the rod and the rotating assembly moved ok. The curious thing was that the piston fracture appeared somewhat old (not shiny like the case and had light carbon deposits), like maybe the piece had broken off on a previous trip and just then jiggled into place where the flying crank blasted it through the case.
Anyway, my question is this - being as how there was absolutely no indication something was amiss prior to it failing, what sort of thing could have led to that happening? I used quality Johnson oil at a 50:1 mix, it appeared to pump water well, and while I sometimes ran it WOT, I did not keep it there nor was it WOT when it happened. I'd like to avoid this happening with my 1976 85hp, so any tip about how that could have happened or what to periodically check would be appreciated.
Thanks!
Thanks!
