Hi all - first time poster here. I've got a 2002 50 hp Yamaha 2-stroke on my V1965 Carolina Skiff - the rig is run in saltwater. I change the plugs every Spring & by season's end the lower 2 plugs have a fair amount of rust on them. The lowest has the most, the bottom half of the middle plug some rust & none on the top plug. So it would seem that water is entering the case from the bottom & spraying up, but I see no spot where water can enter. The gasket is fine & it seems almost impossible for a spray of water to find it's way past the seal at that location. I did notice that the water coolant discharge line runs past that area, so is it possible that I've got a pinhole in the discharge line?
Thank you for your time.
