Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Drain the carbs, and get as much water out as you can, with the plugs out turn her over to get the water out of the cylinders. Take the cap off the dist and wipe it out. Use alcohol and wd 40 which will combine with water and help it evaporate. Then take her back to the lake and see if she will start. If she does run her until all the water is out and the engine warms everything up (several hours). If it will not start, you may have to tear her apart. Good luck JR
