Re: moter will not rev consistantly
it could be a lot of things, link n sinc, as mentioned, compression, spark, clogged carb,,, fuel pump gas tank vent not completely open. fouled plug. i voting partially clogged high speed jets.
is it running on all cylinders, with engine running, insulated pliers, pull 1 spark plug wires one at a time, then replace. it should change rpms equally when each different wire is pulled. and pick back up when reattached. if it doesn't that cylinder isn't running.
