Hello All,
I have an OMC V4 and I think that I have a problem with the engine. I was going about 5,000 RPM for about 5 minutes up the river and out of the blue the egine stopped like I shut off the key. Not like all together stop like something broke. Anyhow, with my wife and three kids on the boat, I attempted to restart the engine and the starter would not even turn the flywheel an inch. So I started my other engine and got back to the marina safe. Mind you at the time this happened, there were not warning buzzers going off. So I let it sit and came back the next day. Engine started right up no problem. Took it out and the same thing happened, the engine stopped running. Now when the engine cranks it will not idle and it has an uneven cranking rythem. So I called the mechanic and he pulled off the port head and said that one of the cylinders leaned out and said that the whole thing needed to be rebuilt. About $4,000.00 Keeping this in mind, this guy rebuilt all 4 carbs, replaced water pump impeller, 4 new spark plugs, wires, new thermostats, and water pump impeller about 1 month prior. He says that it just happens sometimes? Any ideas?:'(
