Sea King help?
pskaggs
I just picked up a 15 hp Sea King for a hundred bucks. The model number is: GG18734C. The serial number is: 36X873230. Can you tell me who made it and what year? How can I get a shop manual for it? How about parts? Do you sell the manual and parts?
Thanks for your help.
Paul
steelespike
Re: Sea King help?
Your motor was built by the Gale devision of OMC.
1963 the last year of production.The 15 was in production from 60 to 63 A service manual for the Evenrude Johnson 18 of the same years will serve you well.The 18 has a larger bore but is essentually the same.Fuel mix is 24:1 Keep in mind that the lower main and the piston wrist pin are not ball/needle bearing
so you should probably stick to 24:1
F_R
Re: Sea King help?
Your motor is a 1963, last year Gale made them. It is a Gale model 15D15P. I have not been able to figure out what the P means.
F_R
Re: Sea King help?
But I strongly suspect it means it was made in Peterborough Canada
pskaggs
Re: Sea King help?
Thank you VERY much, especially about the 24:1 fuel mix. I was about to test run it with a 50:1 mix.
Paul
