1979 25hp parts wanted
bill2003
I have an old Johnson 25hp. I just started it up today and it runs great after a carb kit. I noticed that the throttle control on the tiller handle was not working right. I took the tiller handle all apart and cleaned out the old grease. At the end of a brass/bronze horizontal throttle shaft there is a gear that has a bolt going through the grear for tension. It is broken in 2 pieces. This gear turns another gear that is at the bottom of the throttle linkage rod, this rod goes up along the side of the motor. The broken gear is aluminum. The previous owner tried wiring the gear together but it is not working now. There are some numbers on the back side of the gear that read: 303142 D-2 2. I have no idea were to get a new gear. I am thinking about putting JB weld on it to see if that works. Any help/suggestions would be helpful.
Thanks,
Bill Boyce
JB
Re: 1979 25hp parts wanted
tcoutboard.com
alden135
jb weld won't work. I had the same problem and tried that. Contact tcoutboard like JB suggested. That's where I got my replacement. I think it was around $20.
F_R
If you have a local Evinrude or Johnson dealer, that would be a good place to go. 303142 is the part number.
