Re: 200 EFI Question
Don, the individual who worked on this motor, worked at a Ranger dealer beforehand, Did he check the reed plate? I don't know. I would assume so. Again, solid reputable guy here. Has MANY customers. Works out of his home.
Reason for the semi rebuild was cost. $3K versus $7500 for a new powerhead on a 10 year old boat. Lost one cylinder. (forward most one) Zero compression. Frozen. Hence the crank was damaged to the point where it had to be replaced, plus the one piston, and rod. Shut it down real quick, or damage would have been much worse. I drive this boat easy, but the owner before me probably did not.
Jeff
