After cleaning the carb and doing all the right stuff, points, timing, sync, plug wires, it seemed to run good. But the water pump seemingly was not delivering.
Pulled the lower and did the kit thing. Put the lower back on but found that it would not go all the way in by pushing. Did all the measurements and everything was in order. Put it down to tight seals and carefully pulled it in with the bolts.
Now we have a motor that will, with effort, started up but it only ran briefly and after some fiddling could get it to run for some minutes before it died. Motor temp is way too high anyway. Checked the set up again. Seems like fuel starvation, took the carb off again and checked everything. The needle jet was a bit sticky but no crud.
Cleaned and freed it up. Pulled the out hose from the fuel pump and turned the motor over. Fuel pumps all over the place. Corrected a kink in the line to the carb.Tried it with choke, without choke. Tried adjusting the slow running mixture,1.5 turns up down, didnt make any difference.
What haven't I done?
Got any ideas fellas? Help!:|
