A1SlowHand
- Mar 25, 2007
- 9
Howdy all,
I have seen where a ton of questions has already been answered on this site, and looked for the answer to my question. But could not find it so .....
I have a 1978 Johnson 150 model number 150TL78S and the Ser # is J5008633.
This history is this boat and motor lost froward gear while on the water. I assumed I probably needed to do some lower unit work. Time and money did not allow me to do that then. Now 4 years later I'm starting the task. I thought I would first turn the motor over to see if it had froze up while sitting. She turned over just fine. But I noticed smoke from the postive terminal on the battery. Sure enuff it was hot enough to burn the fingers.
So I started running some continuity testing. I was getting a continuity between the engine ground and the hot side of the starter soleniod when the ignition switch was in the on position. I then separted the red connection plug and seem to think the problem is in the ignition switch area. I have conntinunity between the red/purple and the purple wire when the switch is in the on position at the red plug terminals. Is this normal?
Any help, ideas, pointers, suggestions???? Shoot even a howdy right now would let me know I not alone. d
