Re: Yamaha 150 Four Stroke 2004
anything that triggers RPM reduction will also trigger audibleand visual alarms.
if the alarm system is working I would chase fuel
the F150 has 3 filters on the motor and one in each injector.
any of them clog and the motor wont go.
I got cleaning the VST on an F150 down to an hour, 15 min more and I can r&r the injectors too.
2 quick and simple fuel system tests,one is to check the railpressure, the other is to simply squirt fuel from a squirt can into the throttle body when it bogs.
if the railpressue is below spec, check both prefilters and the VST filter.if railpressure is ok and the engine picks upby spraying gas down the air horn.remove and clean the injectors.
