Re: Generator
If the water pick-up is on the bottom of the boat and fitted with a scupper type pick-up, yes. If it's just a round thru hull pick-up with out a scupper, no. Most small Kohler and Onan genset instructions say not to run them above idle speed. Reason being, they are not factory equiped with scupper pick-ups. Kohler claims that if you run a scupper on their gensets you may force water past the water pump impeller and cause possible engine damage.
