Hi folks what a great site!Glad you exist!!
I have a 1990, I think , v6 Johnson (150). Bought it with bad head gaskets. I replaced them. Boat ran great for 3 trips.
Last trip out, It was alittle hard starting but OK. When I went to Full throttle, it would start missing right away and would shut offat around 3000 rpm. It had no problem restarting but then can't get it over 1500 without misfires. Pulled the plugs at the dock and noticed they were oily and wet. replaced them, drained bowls, (ckecking for water) and restarted. Same thing. I also pushed the choke as engine ran to check if choke was stuck closed, it would kill the engine, so I assumed that wasn't it?
When I took it home and started it (runs ok at idle but definitely hear a mis) I put my hand on cyl heads and noticed that they were just warm. I also noticed that the plugs were also, just warm.
When I did the head gaskets I did not put in the thermostats, I took them out and just left a restricing part of them.
So probably opertating temp is too low, but it did it run real good before? I live in S Florida water temp doesnt change that much?? Should I try a hotter plug? Is a higher number, a hotter plug?
Thanks again Please Help!!:'(
