How much does a 1970's 70 hp Chrysler weigh?
Motor Boater Bill
A friend has offered me a 1970's 70 hp Chrysler outboard. It is on his old boat and I'll need to get it off, put it in my pickup and remount it on my boat. How much does one of these things weigh? I'm trying to figure out what I'll need to do this.
Thanks!
steelespike
Re: How much does a 1970's 70 hp Chrysler weigh?
In the area of 260 to 270 lbs.
Frank Acampora
Don't let the weight scare you. With a little planning and forethoutht, you can "roll" the engine off the transom and into the truck bed. Lifting it onto your boat requires three people or an A frame made of 2X4 legs and 2X6 crossbeam with a come along to lift. Wrap good rope around it and secure well or make a lifting jig that bolts to the three holes in the flywheel.
I'm 61 and of average strength and I handle these engines frequently with no trouble.
Motor Boater Bill
Thanks to both of you. This is very helpful. Frank, when you say to "roll" it off the transom, can you explain just a bit? I'm imagining that you mean to put the motor in the raised and locked position, with the skeg over the truck bed, then roll the motor onto its side so the clamps come off the transom, then slide it on into the truck. But I'm just guessing. There will certainly be at least two of us at that end of the operation. Once I get the motor here, I have lots of options for rigging things, come along, timbers, etc. I might also be able to borrow a cherry picker (the motor lifiting kind) if that's not overkill.
Frank Acampora
I would first take off the hood so it doesn't break if the engine gets away from you. Then I would back up the truck, with the tailgate down, real close to the boat at 90 degrees to the transom and a few inches away from the engine leg, After loosening everything holding the engine on, the two of you should lift it off the transom and let it slide under control, down onto the tailgate until it is resting on the "support plate" on the edge of the tailgate. This is the pan shaped plate that the hood sits on. next, grab the lower unit, lift, (which, depending on the height of your truck may be resting on the ground) and just roll it into the truck and slide it forward into the bed. If the steering goes through the clamps, you may need to slide the engine sideways to remove the steering cable so leave room for that. Use a blanket or two or even a small sheet of plywood--big cardboard boxes etc. so you don't scratch the tailgate. A few ropes wrapped around the block make it easier to handle. With two people, (One standing in the truck and one on the ground) it's a piece of cake.
The engine clamps are bolted through the transom so you will need two 9/16 wrenches, and one person in the boat and one outside. In the well they will be either tightened by hand screws or a 9/16 hex screw. Steering--depends --maybe 9/16, maybe 1/2. Flat screwdriver to remove control harness wire. Depending on how the control box is mounted to the boat, you may need only a screwdriver or, you may need a screwdriver and several smaller wrenches if it is nutted in the back. Ignition Switch will require either 7/8 or 15/16 wrench or a big adjustable. Control cables are connected to the engine by quick connect fittings. no tools necessary. Starting cables 1/2 or 9/16 depending on solenoid nut and ground bolt. Fuel line may be held on with a wire clamp needing a pliers to remove , or a screw clamp. It should take about 15 min to 1/2 hour to remove everything and get the engine ready to dismount.
Motor Boater Bill
Thanks for all the great info, Frank. I'm not sure when I'll be able to get over there and tear into it--maybe next weekend if I get my taxes done! However, I am thinking that perhaps I will see if it fires before I go too far. I might take a can of premix and squirt some in the carbs to see what it does. I did turn it over with a jumpstarter several months ago, so I know it isn't locked up. But if it is going to need a lot of work, I may pass on it (I do know that any old motor will take a certain amount of time and parts to get ready to use). Either way I'll end up wrestling some mid-sized motor before long, and your information will be invaluable.
justin65
I was just wondering if you could modify an engine hoist to lift outboard motors?
