I have recently bought a 1971 18' Starcraft Starchief to finish restoring. New to the boat scene. It has a Johnson 100hp hydro-electric motor.
My question is on the casing of the throttle assembly there are the wires coming off the back wich i have all hooked up and are working but there are 2 wires coming out the side. One is white which has power when the key is turned on. (assuming for the keyed power for lights and what not).
The other wire is Red-blackstripe and does not seem to be a ground or have power with key in any position. Would like to know what thats for before i hook the white one up to a fuse box in case im on the wrong track.
There is also a toggle switch that looks like what you would raise and lower an outdrive with but the toggle only goes up and the drive does not have a system to raise and lower. ??
Thanks for any help in advance. Cant wait to get this thing in the water
