Naden Update
JimMachinery
Hello:
I haven't posted in a while bacause I had trouble getting back on after the change in the forum. Taking things off of boat is going O.K., undoing the wiring is slow as I have been making tags for each wire before I pull it. Should have the motor off soon if I get some time to build a stand.
This boat restoration stuff could take over your life if you let it!
Bob_VT
Re: Naden Update
Looking good. SHould be a great project.
Once you get the motor off...... flip it over and do the bottom. Graet time to tend to bad rivets and use gluvit on the inside.
JimMachinery
Re: Naden Update
Thanks, Bob VT!
I heard conflicting things about Gluvit on other posts. I guess it's better than nothing.
I plan to fill boat (to approximate waterline) with water and red or blue food coloring to look for rivets and seams that need attention, but I have to pull the old Mercury tilt pump out so I can get the aft flooring out as well.
Once that's done, I have to make a decision about foam -
