I have a Key West 1520EX with a Yamaha 50 4-stroke. The fuel guage seemed to slowly die, as in it would read 1/4 of a tank when there was actually no fuel in the tank. The gauge then started not working at all. All of the wiring on the back of the gauge is working correctly. Just took the sending unit out of the fuel tank, and here are the results: While in the tank the sending gauge reads 1/4 of a tank; when I removed the whole sending unit and checked the float and mechanical operation of the unit everything seemed fine. while removed from the tank and with me moving the float assembly the fuel gauge on the console and on the sending unti itself worked fine, however when i placed the unit back into the fuel tank the same thing happened (the gauge at the console and on the sending unit remained at 1/4). So my ultimate question is can the float go bad? That sems to be the only portion of the puzzle that isn't working. I just didn't think that the nitrile rubber would quite floating one day, seemes very odd.
thanks
chris
thanks
chris
