redneck Excaliber sword
jasonh
If any ya'll can pull this out, you'll have honor and stuff bestowed upon ye....
I was fishing at the extreme western tip of Lake Grapevine where it turns into a stump field. Close by was a large sand bar the connects to a main road and several trucks, motorcycles, 4-wheelers, and even a sand rail buggy were racing around having a good time. Soon I heard something stuck. It was an old Bronco II with a mild lift and it was stuck to the rocker panels half in, half out of the water. Unable to open the door, this guy climbs out and stares at his predicament. Within minutes a F250 diesel shows up and backs into position to pull him out. After a few minutes, he's managed to get himself stuck too. The two guys are conferring about the situation when another truck pulls up to try. This one has the Skyjacker suspension and sounds pretty good, but unfortunately does not have a chain long enough to stay out of the muck, thus winding up like the 1st contestant. He just has a big rope. He ties this on and even from my vantage point 50 yards away I'm cringing because I can see this rope stretching as the truck lunges forward. Then there is a loud POP! immediately followed by a sharp explosion. The truck trying to pull the other out now has a busted rear window from the rope whipping into the back of the cab. After some cursing and consultation, the guy starts trying to dig his truck out after Skyjacker decided to leave before A-1 Autoglass closed. Several other lesser vehicles all took turns trying to extract the Bronco and F250 with zero success. As I was leaving, a tow truck rumbled into view. He was followed by a Grapevine cop.
Bad day at the lake.
8AteEight
Re: redneck Excaliber sword
Thats a pretty scarey thing to do!! There was a kid 'round here who lost 2/3s of his face because a huge (7"dia.) rope snapped while he was trying to pull out a tractor. they found him a day later, tractor in a ditch, breathing through a pool of blood.
kenmyfam
Ropes are scarey in those situations. Better a chain that would haul up the Titanic !!
puddle jumper
The big thing to do when using a rope when pulling something is to put a coat on top of it or something like that.It will absorbe all of the shock from the rope if it were to brake.Sounds corny but works.
Bass-A-Holic
Another thing to do is if possible, put the hood of the vehicle up to protect from the rope, or cable. Beating up a hood is better than injuring yourself if something snaps.
beezee28
Master Chief Petty Officer
Yeap, seem a rope pulled to its limit and then snaps, sounds like a cannon shot and the rope whip around so fast that it broken a young sapling about 6" in diameter clean in half. Can you imagine if a person is in the way of the rope probably would have cut the person up pretty bad. I try to use chain whenver I can for towing.,
Bass-A-Holic
Yeah, i was watching "Mail Call" on tv and they were talking about pulling out stuck humvees ect... They use steel cable, but they said that if you get in the way of one and it snaps, it'll cut you in two.
bassboy1
Nope, Mythbusters tried it. The force is enough to do it, but the direction of the force is usually incorrect. Could rip half your skin off, but would be tough to get it going in the right direction to sever you.
