Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
My Mariner 9.9 will not idle. It runs smooth and consistent at WOT. The telltale has a good stream, so cooling system is well. What is the carb setting? and where should I set the ignition advance at, What is the proper adjustment for it?
Well I cleaned the carb and it wasn't dirty. There wasn't even any sediment in the carb bowl. The mariner still will not idle I believe the idle stop screw was moved and the idle airbleed screw is opened too far. I'm sure that 4 turns open is too much. What are the default settings for these two adjustments?
