redjmp
- Mar 16, 2005
- 536
I just got a pull start '76 50hp 4 cyl ser#7069013 (Canada).
Starter has been added along with remote keyswitch and choke button with only 5' lead. I will remove these and install them in the control housing which right now has an empty hole for choke and kill/run switch instead of key.
I will need to find a choke solenoid and plunger and rewire controls from 2 wire to 6 wire. I guess any 50 hp choke will work?
The real problem I have is trying to determine which stator #'s will fit and what is the difference between them?
I see black ones and red ones on ebay but I don't know which model applies to my engine.
Oldmercs says a 398-832075A20 will fit but are there any other choice's, as oem, this part is over $500 Cdn. As well, are there any other parts I need to swap in order to make this motor charge such as the trigger plate or can I leave the original alone? I know I will need a rectifier.
Thanks so much.
Thanks so much.
