sibylernie
- Apr 27, 2007
- 10
Recently installed water pump kit with help of this forum.Thanks! Now the engine will not start. Probably not related to installation of kit. Engine did start and run well before kit. Plugs are wet after trying to start so it could be firing problems. Should I replace plugs and wires before have a professional look at the motor? I noticed some corrosion inside nipples that attach to plugs. Could corrosion on battery terminals be culprit? Are there other things that I can try? Also, there seems to be an abundance of oil in water tank after several attempts to start engine. Had new (wiring harness?) installed last year.
