erikgreen
- Jan 8, 2007
- 3,105
I just put two layers of 18 oz. roving on my new transom, which is itself made of two 3/4" ply layers glued to the existing gelcoat with epoxy with filler and laminated with glass between. I filled the remaining space around the edges of the ply with peanut butter epoxy, and filleted. Then I started laminating.
I learned everything on how to do this from here, this is a great board!
I thought I'd post some pics so you could all comment on my (lack of good) workmanship.
I obviously need to do some cleanup on this yet, clear the hole for the sterndrive, grind out and fill some voids in the glass where I cross chines.
Also, I still need to put a couple layers of 8 oz glass on the ply to finish the transom interior. The white fillet you see behind the roving is actually matting, I just laminated it on with some white opaque epoxy because I wanted to try it out - it's certified as useable for lamination, and seems to work ok. Turns out I didn't need the mat since I'm not using polyester, but that's ok.
Edit: The white stuff right in the corners there isn't a bubble, it's dust from a bit of grinding I did before I took the pic - there's some on the ply too.
Next up are the motor mounts.. they go on either side of the remnant ridges you see near the transom hole. I'll remove the ridges and some more foam and stringer before I put them in.
I'm thinking of laminating some ply together with epoxy on edge, so the pieces are vertical, to make the motor mounts, which are 38" x 7" x 5 1/4 on the inside, sloping to 4" on the outside. Sound reasonable, or is there a better way to match the slope? I don't have a planer or even a big router.
Erik
Erik
