stains on seat
I sat plastic bag from parts store on seat with my new oil in it for 2 days. When I went to change oil I found that I have the name of store printed on my seat. how can I remove it? Have tried everything I can think of. No luck
Gary H NC
Re: stains on seat
Goo Gone is great stuff. If that doesn't work a little greased lightning but test it on a small area first,its pretty strong stuff..
studlymandingo
Re: stains on seat
Call the auto parts store and demand sponsorship money!!! Maybe you can at least pay for the next oil change that way!;)
crazy charlie
Re: stains on seat
My friend had the exact same thing happen with a hot dog roll bag.WE TRIED EVERYTHING !!! Magic erasers,scotchbrite,goo gone,bleach,aerosol hairspray,tarn-x,rust away,softscrub,nail polish remever crazy clean,EVERYTHING.Sorry to say that nothing worked.
mercurymick
stains on seat possible correction....
i run a auto \marine and commerical upholstery biz, you can try some plastic and leather prep with a scotch pad gray from 3m spray on and scrub in same direction left to right keeping wet may take it off, these products are available through sem corp. also if it doesnt come off it will need to be re dyed. This service i provide however your location may be a problem!! : Im located in illinois rips cuts tears in vinyl, plastic ,repairs ,faded pieces all can be corrected or replaced if you know the right guy! mick
Mark42
Re: stains on seat
I had the same thing happen to the beige leather seats in my brand new '96 Camaro. Thought I would die. Anyway, the trick is most, if not all of those bags are made with biodegradeable material, including the ink. I waited about a week, and with the T-tops off, the sun faded it completely away. No more red and blue auto parts store logo on my seat!
Give it a week or so in the sun and see what happens before attacking the seats with anything abrasive.
Mark.
Bay-185
Re: stains on seat
I did the same thing with a PFD after I picked my boat up new!!
It cooked the name right into the seat. I too tried everything and nothing worked until I tried acetone - i applied it several times directly to the mark and after awhile of rub rub rub it came right off with no damgae to the seat.
I then rinsed it down and put some seat protector on it.
give it a try it should work.
good luck and let me kow
daniel2229
Re: stains on seat
I stained a seat using hot pink crappies bites. Once the bait got wet, I didn't realize it couldn't touch anything until it was way too late. It only touched the seat for maybe thirty seconds!
I was unable to get the pink stain out even with bleach.
