electramatic shift throttle box wiring
62johnson40hp
i managed to get the orginal shifter control that came with the engine i got 1962 johnson 40hp electramatic,,the control has no F,N,R, buttons, just single cable throttle box with 5 wires coming out of it witch are:
Green=Forward, Blue=Rev, Purple=12v+??? and 2 White=??? im not sure where the white wires go and if the purple wire gets 12v+.
nehelp appeciated thanks
F_R
Re: electramatic shift throttle box wiring
You got me confused by now. Is your motor a '62 40hp? The original for a '62 40hp would not have the white wires. The white wires are for the start in neutral part of the switch. That was used on high horsepower models such as 100hp, and Inboard-Outboard Stern drives. The 40hp has a safety switch on the motor and does not need another one in the control.
But you can use the one with white wires, just don't connect the white ones.
Make sure the other control switch function matches your motor. There are two basic types. Electromatic and Hydro-Electric. They look alike but are different. Using a Hydro-Electric switch on an Electromatic can damage the lower unit in an instant.
62johnson40hp
hmm..well mabe i dont have the orginal ,,this was said to be it, i took a few pix of it,,and i found a part # 981160 if that helps.
thanks
F_R
That's not what was shipped with the motor from the factory.
62johnson40hp
oh great..that sux..!! i wonder where he(neighbour) got this..!! hey,, so it would still be alrite if i used it?? Just hook Purple=12v, Green=Forward, Blue=Rev.? and it hopefully should work? its weird cuz it hooks up to the throttle on the engine! ,thanks alot for your help Imported F R. :)
itstippy
Don't hurry things. Go slowly and deliberately. Read FR's post again. Do it wrong and you can destroy the lower unit. That does not mean "hook it up and hopefully it will work".
If memory serves me you have a green wire and a blue wire coming out of the lower unit. The entire unit is grounded (12V-). The motor is in neutral when no voltage is applied to either wire. 12V+ to the green wire puts you into Forward. 12V+ to the blue wire puts you into reverse. 12V+ to both wires puts you into both forward and reverse at the same time and if the motor's running you just destroyed the lower unit. You DO NOT want to have to rebuild that lower unit!
Test the controller you have to make sure it's set up that way.
http://forums.iboats.com/showthread.php?t=168325
F_R
That control might have been installed by the boat builder. But that does not matter. What matters is the switch. Get yourself a test light or meter and check the continuity of the wires in various shift positions. There should be continuity between the purple and green when in forward, between purple and blue in reverse and no contiuity between nuthin in neutral. If it passes the test you are good to go.
Mustang 6
I recently acquired a 1967 Johnson 40 Hp electamatic on an old boat. The control has been taken apart and some parts may be missing. Is there a manual available with an illistrated parts breakdown? The engine appears to be in fairly good condition from outward appearances so I think it is worth some effort to repair. The boat is another question, 1967 Stinger I think not sure yet on how to proceed with it.
