Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Ok so last night I got all my wiring done with a new switch and found out my choke is shorted. If I move the power connecter on the choke it will work but only when you move it. Can you buy a new one cheap or what do you have to do to fix it?
there nothing cheap about a boat. i searched for a replacement. came up with "0". take solenoid off and see if you can solder the connection. could not come up with parts number. but try tcoutboard.com
Hey, "boat parts" and "cheap" don't go together. However, the part number is 376806, changed to 385554, both listed as no longer available. Try Laings at http://www.laingsoutboards.com/
I found two places that have it. One wanted $85 shipped and the other wanted $107. The http://www.laingsoutboards.com/ was the one for $85.
But for $85 for something that moves an arm when power is on it I think I am going to pull it off and see if I can fix it. Its just shorted out so I should be able to fix it.
