3.7 mercruiser, homebrew alternator conversion, $80
Status
Not open for further replies.
andy1canada
Re: 3.7 mercruiser, homebrew alternator conversion, $80
Howdy!
Awesome job!
I've seen these conversion kits listed on ebay for about $400/US. You saved yourself a bundle.
Incidentally, if you don't know about it already, there's a forum on the web called 'Breezeworks' that's chaulk-full of '470' owners like yourself. I'm sure there's a 'whack' of guy's on there who'd like to see the job you did.
Good luck with your killer four-banger!
Cheers,
Terry
jasiffe
Ecupir8,
Used your example and installed a 100 amp marine alternator (purchased new on line for $69). Bought an upper bracket from Auto Zone for $13 and made the lower bracket from 3/8" steel stock hacksaw cut in three straight lengths, then drilled & rounded with an ordinary shop grinder. Used washers for appropriate depth spacing. Measured the belt length & purchased at Auto Zone for about $8. No special tools required. The unit charges beautifully, and total price around $100. I recommend this to anyone considering buying the $500 kit. My dog house had to shift about 1" to the left to allow for side clearance, but I do not have seats there so it did not make any difference for me.
volcomstone550
you should scan the brackets you made to scale so we can all have the design and simply print it out
Todd Peterson
I would like to see your bracket or draw it on paper. I just hate to pay $200-500 for a bracket when the alternator costs $200.00.
I just took out the magnets and stator and need a kit.
Do you know where I can a used bracket?
Todd
Don S
Don't expect an answer from this year old thread. Here is the info on the original poster.
ecupir8 Last Activity: June 12th, 2007 05:50 PM
Todd Peterson
Don, thanks for the links. I see that I can buy the kit (less the alternator) for $157.00 and then get the alternator local for $200.00 and install my self. I found install instructions too. Now I have to pay the marina for a new head gasket.
Don S
:confused: :confused: But I didn't post any links :confused: :confused:
Todd Peterson
Don, ok.
Thanks for the guiding me to the old threads. I found info from there.
telstar1
Did you remove the old magnets from the pulley on your unit?I did a similaR CONVERSION AND AM NOW WONDERING WHETHER THOSE MAGNETS WERE NEEDED FOR THEIR WEIGHT IN THE PULLEY which is also the vibration damper I think??
Todd Peterson
The local marina went to mercrusier and asked that question. The magnets do not need to be there if you go to an OEM alternator kit. I found the kit for my 470 mercruiser for $299 at http://www.breezeworks.net/
Excalibur
Performed this conversion on an 89 Thompson Carrera 200 with a 3.7 last season using the kit from Wagner (WAGDC60). Very tight fit involving cutting the deck and moving the engine cover forward and installing a 2 inch upolstered spacer behind the seats. Have lots of tips & pics if anyone is interested.
fiber
Excalibur,
Very odd that I happened upon this thread. My Voltage Reg just went out on me and was looking for a better way than bitting the bullet and ordering one from Merc. Any pictures or tips would be of great help to me as I am planning on tackling it this next weekend. Thanks in advance...
a1nowell
:confused:
Fiber,
You did not mention whether you have made the alternator conversion. If you have , I have been told if you go to a 3 wire alternator you can bypass the regulator completely.
Can anyone confirm this?
I haven't made the conversion yet but probably will soon, old altenator only putting out about 12.5 volts.
Larry
abj87
:confused:
Fiber,
Larry
Both one wire and three wire dont use the factory regulator
Status
