Transom clamp
Frank Acampora
Took the 21 foot Manatee with the Force 125 out today. This boat always goes on the trailer crooked and aggravates the hell out of me. So when I got home I started to play around (again) with roller spacing.
While I was at the transom, I noticed the starboard clamp was flaking on one side at the top bolt location. Probed it with a small screwdriver and lo and Behold! two pieces about 2 in square and 1/8 inch thick came right off--I could see the full length of the mounting bolt. So, I've been running with a clamp about 1/2 the thickness it should be. Must have been a defective clamp because I have never seen a clamp fail in this way. Has anyone else out there ever seen this?
You can be sure I won't be running the boat until this is replaced. Only problem is that to replace it, the engine needs to be removed from transom and the tilt/trim needs to be disconnected from the clamp. Lot of work on a salt water engine. You know that with the inevitable corrosion there's going to be a lot of cussin' and swearin' and at least 1 snapped bolt.
Oh, well! I needed an excuse to mount my 140 on the boat anyway
MWBROWN
Re: Transom clamp
Frank,
Never had that happen, but it is scarry.
Good luck with your project.
Mike
RRitt
Re: Transom clamp
sounds like a saltwater boat with a serious galvanic problem. on the bright side, it might be a good time to replace the kingpin and then the boat will steer like new.
