My fishing buddy purchased a used G3 Eagle 165. This is a modified V type boad but the angle of the hull runs from bow to somewhere about the drivers seat.
We fish at a no power loading ramp and because of the angle of the hull, no part of the boat touches the bunks until the nose is already under the post roller by about a foot.
I took an old post/roller and mounted them behind his post and positioned the roller against the hull to force the boat up toward his post. This would have worked pretty well except I forgot about the hook eye which went over my roller and loaded fine. When we attempted to unload, the eye would not go back over my roller so I walked the plank, raised the nose of the boat and smashed my finger between the boat and roller. Project removed!!
Putting the trailer deeper until his post is low in the water results in the gurgling sound of a Ford running underwater and putting the trailer in shallow enough to force the hull to hit the bunks results in having to crank the entire weight of the boat up most of the trailer.
So, any ideas appreciated. Some kind of rollers that would mount on the trailer frame on both sides to cradle the hull upward?
Thanks
DaveJ
Thanks
DaveJ
