freddiemercury
- May 10, 2007
- 1
I have a Mercury 888 which is a v-8 Ford 302 small block CID 5 Litre in an 17 ' Aquarius Invader. I have changed the battery, new ignition coil, new plugs new plug wires and I still need to keep closing the carbeurator butterfly to get it to start. Then I remove the post I use to close the carb butterfly once it is started and running. Otherwise she runs smooth and fine.
My starting procedure is to pump the throttle twice to get gas into the carb and then set it to about 1/3 which is what another owner here told me he does and he says his gets started all the time.
I am looking at adjusting the carb ratio to be more rich to see if this will help.
Any suggestions would be greatly appreciated.
