hi,
this weekend I had picked up my boat from repair shop, it had a crack cylinder on the power tilt and trim, plus i had the prop replaced cause it was chewed up a bit. The prop I don't know the size, but do know it was a 13 pitch. I told the mechanic that I was feeling sluggish and only maybe getting 5500 rpms. So he did his research and bumped it to a 11 pitch. I took the boat out and wow what a approvement that made me happy. I ran the boat later that night, fishing and the next morning out to the fishing hole. Rain started to look like a might, so we started to head in. I was running almost 6000 rpm out of the cove and turn the boat towards dock. After the turn the motor lost power. I was running about 3800 rpm. I tried shutting it down and starting again. When i mash the trottle foward the motor shakes a bit and then goes to the 3800 rpm, no more. I get the boat back to the shore and to the mechanic, I told him I was thinking plugs. change the plugs and said the bottom plug looked okey but not great. He also said the trottle cables and mechanisms were working okey. He also said I could of got water in the gas??? Okey so I took the boat back out to see if plugs were it nope, no cure. I ran the boat alot afterward but still can't get the rpms up. The motor runs fine trolling and slow takeoffs. I brought the boat home hoping to avoid any mechanical expenses if possible. Anybody have any recommendation where to start?
thanks
thanks
