$$ this omc cobra 5.0L outdrive is worth
Hardboiled
Just wondering if this Outdrive OMC Cobra for a V8 5.0L is worth something
I took it off a boat i have that im looking forward to trash it and the engine is stuck with water in it, but the OUTDRIVE seems to be in good working condition but i never got it working because had no engine.
can i sell this outdrive online somewhere, i even have the the other parts like the flywheel with coupler in good condition and all, all this needs mainly is Paint and of course some maintaince,i took the PROP out just today and is in good condition is a 14/5 x 28 Raker
any sugestion thanks you very much
Boatin Bob
Re: $$ this omc cobra 5.0L outdrive is worth
Should have no trouble selling it on ebay!
Hardboiled
Cool great thanks
But i have a question, is it good to sell it all together or by parts ?
anyway if i sell this through Ebay, how do i Ship it to the buyer or i have to pack this big Heavy drive or whatever im confuse in this part and i can't decide how to do it if you can give me some short explanation how to do it. thanks alot
uaw9fan
The better question is. Why is there so much corrosion on the inside of the transom? Was the boat sunk for a long period of time?
As far as Ebay goes, it's your call. Usually you can get more if you piece it out and it is easier to ship.
bruceb58
If there was water getting in from the rear it also means there was water in the boot which also means water probably got in the drive.
What does the drive oil look like?
Hardboiled
The oil looks dark
i think the reason that bar that goes into the coupler is rusty is cause between the transon and plate holding it the boat seal joint around it look pretty bad since this Outdrive is not original from this boat and the boat plywood holding it is very soft so thats why water was going through there i think, the rest looks fine
Gary H NC
I have seen those drives sell for at least 1500 on ebay. Clean it up and shoot some paint on it and list it.It will sell!!
delsol
my buddy had his rebuilt for 2000k last year by don ruesell marine i think .. nice job the gears were broken
bob
Hardboiled
wow $1500
at least $800 or 1000 will be enough, i can paint it and make it look like new but that would be bad for the buyer if i try to make it too nice from outside and i don't know what's inside, but 1 thing im sure is that this outdrive is in working state and something that bother me now is the Rusty transom bar that goes to engine coupler, i think i can take it out and sell it without it cause everything else looks in good shape, just need paint and some details.
do you think if i take the gimball housing part out is better to sell it? cause the aluminum on the back is la little wasted by the salt.
will see, like how much this outdrive weight if any know? cause if i sell it all together is better to me, do i have to call UPS first before posting it on ebay.?
when i sell on ebay i do the shipping myself or ebay has anything to do with it?
Gary H NC
The shipping you need to handle. I would pull the 6 nuts and remove it from the gimbal housing.Maybe take the u-joints out and remove the rusted drive shaft. If the oil is not milky in it just put in your add that it was in running condition when removed from the boat.Being honest on Ebay will pay off.
Hardboiled
awesome
i will do that thanks, the OIL inside looks normal is not milky and the one that had water was in the v8 ENGINE it looked milky. the engine didn;t have the oil measure strip and the pistons inside had something that looked similar to sand and white but was not sand probably the same fuel created that. whatever cya
