sheldonthoms
- May 18, 2007
- 1
I have a 4 cylinder 60hp sea horse. The motor starts and idles ok but when open will bogg down and backfire, boat will no longer plane. There is a large amount of gas leaking into the water as well. I noticed when i prime the gas line that gas will pour out of a brass circle just above the glass filter. I assume thhat there is a seal somewhere. Does anyone know how to get a repair manual or picture off the net? I also need to figure out how to clean the carb. There is also an intermetant bang in the gears in FWD every so often, almost like running oversomething. I assume it is because of the old gears, should i go with a thicker gear oil, or purchase a new gear switch, and lower end.
Thanks
Sheldonthoms@hotmail.com
Thanks
