My 302/175hp in an 18' Cal glass v-hull runs 41-4200 RPM with a 14X19P prop, so you may be close. Only the water will tell.![]()
Yer luggin it RN. You should be able to get that thing up to 46/4700 rpm at WOT. I'd try a 14 x 17, expecially if you are pulling or have a boatload. My '75 190 hp(w/later hydro Mechanical drive @ 1.50:1), pushing a 20 ftr with a full boat load would pull 4900 rpm using a 15 x 17 prop (B4 5.0 liter roller cam engine). You might have an electric shift and 14" props were usual.
First, I was off on my last post. Just looked up my notes and I'm 42-4300 with full load with 14X18P prop. I'll go edit that.
46-4700? My manual gives 38-4200 rpm for the Ford 302/175hp. I had a thread in the prop forum last summer and tried different props and was advised I was good. I started with a 14X16P and was at 4800rpm. Given the age (75), tho in good condition, I didn't want to push it too much from the book #'s.
Just found my old thread here:
http://forums.iboats.com/showthread.php?t=175460
I haven't tried pulling any skiers or tubes yet, but would it be better to use the 16P for this and use the 18P for general use?
Of all the stringers, a 1984 is one of the best versions, it's full mechanical shift and exhaust through the prop like a modern drive.
Some OMC Stringers facts
no u-joints
no gimbal bearing
no hydraulic cylinders under water
no shift cable bellows
no exhaust bellows
no u-joint bellows
800 series Props 15 spline exchange with V6/V8 Johnson and Evinrude outboards
400 series props 13 spline exchange with V4 Johnson and Evinrude outboards
driveline axis stays straight when turning (alas, no ujoints)
larger water pump impeller moves more water than competitors
no alignment tool required
no stress on transom
