Re: need help before starting motor
Ok here is how to get started.
Get a pump bottle put sea foam in it.
Pull the plugs
Squirt in about four good pumps into each cylinder, do this every day until you start the carb rebuild. Put plugs back in but not tight, you just don't want any crap getting in.
Now start the other stuff
Other stuff
Get your motor ID numbers and goto
www.maxrules.com
Call him, He will set you up with the book on the motor and your carb kits.
Don't worry about draining the lower unit yet.
You need the book if you have little or no experience with boat motors.
Order of operations.
1 get carb kits and all new hoses
2 get fuel pump kit
3 get book
4 read book it will show you the general maintence stuff like draining the lower unit
5 get new fuel line connection stuff (wally world has this stuff)
6 get plastic tank and muffs
Iboats has all of this stuff also.
My notes
I would not worry about checking compression yet you are a ways away from that.
In most cases a motor that old is in ok shape because if it had any major problems it would be in the junk pile. This motor is 33 years, old same age as my wife and she has some minor problems. She still is not worn out, but i tryin'
Kyle
