john parks
- May 25, 2007
- 4
I have a 1993 Mariner 135hp 2 Stroke motor. Recently, the motor began to run rough. The number one and three cylinder had fowled plugs. My first thought was the fuel. I installed a water fuel seperator, fuel filter and rebuilt the carbs. The boat ran fine for about an hour and then I could not seem to get the engine to go above 3500/4000 rpms. It ran like it was missing. If I changed the plugs, it would run fine until they fowled. I tested the the switch box and coils. They tested fine. I still changed them anyway. Coils where next. After pulliing the flywheel I found that one of the magnets had come undone. I changed the flywheel and stator while I had it off. Still the same thing. It seems to run at idle fine, but can not get over 3500/4000 rpms and running rough at 3/4 to full throttle. Does anyone have any ideas?
