electric Start
Gymmy24
Hi, I have a Mariner 9.9 motor, with a push button start on the motor. Not sure the year. Late 80s or Early 90s. I think.
Can I put a Key start on the Console to start the motor? And if so, Is there only one type, or will any work. I've seen a few online, but Non have said that it will work only on One type.
And is it hard to do.
I did a search but ddint find anything that helped me.
Thanks for the Help
Gymmy24
tashasdaddy
Re: electric Start
yes you can, but will probably have to make your own wiring harness. go to mercurypartsexpress.com assessories. or check the merc dealer.
studlymandingo
Re: electric Start
It's not too hard at all. You will want to identify the wiring schematic and just run primary wiring from the existing setup to the key switch. A universal switch should do the trick just fine.​
Silvertip
Re: electric Start
Any universal switch will NOT do fine. It must be for a magneto ignition. There are lots of "universal" ignition switches on the marked that are for "battery" ignition. With a "battery" ignition, the stop/run contacts "close" to enable the engine to run. On a magneto ignition switch the stop/run contacts "open" to allow the engine to run. So you need an ignition switch for a two-stroke (with or without the push-to-choke feature.).
tashasdaddy
Re: electric Start
i have use 3 push buttons, with out an ignition. 1 is choke, 2 is kill button, 3 is the starter button. no key involved.
