batt isolator on stator?
issachar
Can you put a batt. isolator on an 92 merc 135 with a stator to charge your trolling batteries? Is this a bad idea?
ricksrster
Re: batt isolator on stator?
I did it.
issachar
You show an alternator on yours. Will it work the same with a stator setup?
Also, do you have to have the switch? I just want to use the excess charge on my trolling batteries.
ricksrster
The stator is the alt. Run the charge wire from the Rect/regulator 12v+. No you don't need the switch
bruceb58
Just be aware that, with an isolater, your batteries will not fully charge because of the voltage drop across the diode.
On my outboard, the charging wire from the rectifier is connected to the battery cable inside the motor's cowling. In order to wire the isolator, you would need to disconnect the "charging" wire from the battery cable, route it out of the motor to the boat, connect it to the isolator and then to the batteries, right?
A better idea is to use a battery combiner. This would be connected between the two batteries, and is a relay tha tcloses to charge the secondary battery, when the primary is fully charged.
issachar
I am obviously no expert, thus asking the question in the first place, but I think you could just wire the isolator right from the other battery. It would only allow charge from the running voltage at first to come to second battery, but I am just sharing my limited understanding
bruceb58
if the second battery was drawn down it would draw current from the first battery.
