southshore
- May 21, 2007
- 22
Ok I still have a smoking problem going from idle speed to higher rpm's. Engine runs good top end although starts to sputter and spew blue smoke about 4 min at idle rpm.
Changed the following items
Decarb (Pulled carbs off and are in good shape)
Thermostats
Coils
Wires/ plugs NGK BPZ8hs-10
Fuel filter ( today)
Primer bulb (today)
Startron in fuel
I was told to look at the recirculation valves Any help on the way to clean them or do I need to replace them. The seloc manual helps but I would like a little more insight into what I am getting into. Is this a hard/long project. Any online exploded views of this area of this engine. Any Help ? Should I look elswhere whith the problem I am having?
Thermostats
Coils
Primer bulb (today)
Startron in fuel
