While trying to isolate an apparent fuel delivery problem, I removed two of the three float bowl drain screws to verify that the float bowls were filling prior to making a decision to clean the carbs. I was surprised to get only a drop or two of fuel from the drains. Does this mean that the floats are stuck in the up position or is this to be expected? I have replaced fuel pump diaphragms and fuel screen. Flow to inlet of carbs appears to be good. My next step is to replace the fuel line, connector and bullb before cleaning the carbs. Any help is appreciated!
Waydrews
Waydrews
